AutoCAD MPolygon with fill pattern colors
  • Jul 2, 2015 4:20 PM UTC
  • 242 views
How do I set the MPolygon line color seperate from the fill pattern color in FME 2015?
Changing the Color value changes both, and setting the attribute autoccad_color (as recommended in a related post) does nothing. If I go into AutoCAD, I can set the line color seperate from the fill - but I'm not sure how to tell FME to output this combo. I am using the REALDWG writer.
Thanks,
Bryan
pratap
Forum|alt.badge.img+12
  • Jul 6, 2015 8:40 AM UTC
Is it possible to provide sample data of input and output?
Pratap
  • Jul 6, 2015 2:47 PM UTC
Pratap,
I received an answer from support. For AutoCAD, leave the Color value in the DWGStyler blank and instead use a FeatureColorSetter before it to set both the boundary and fill colors. It isn't intuitive by any means, but it does work.
In general, the AutoCAD documentation on how to set a lot of these features for the writer really needs some work. FME can output most settings - but figuring out how to do it is somewhat painful as it is not well documented.
Bryan
