AutoCAD block outputs are different between Flow and Form
  • Aug 27, 2023 11:58 PM UTC
  • 43 views
kdwss
Forum|alt.badge.img+3
I've built an AutoCAD based automation in FME Form and use blocks with text for some of the output features. The text aligns how it was designed in the block in the FME Form output.
However, when running in FME Flow the text shifts.
imageIf I move the block slightly, select Reset Bl;ock or edit the text in AutoCAD then it snaps back to the correctly designed position.
imageI'm using the same template dwg in FME Form and FME Flow.
daveatsafe
Forum|alt.badge.img+24
  • Aug 29, 2023 9:12 PM UTC
Hi @kdwss​,
Are your Form and Flow running different versions of FME, or on different platforms?
kdwss
  • Sep 13, 2023 11:49 PM UTC
Hi @kdwss​,
Hi @daveatsafe​
The Form and Flow versions are the same version and build (2022.2 build 22765)
