AutoCAD 3D Object data table read in FME Cloud (workaround/alternative)
  • Sep 9, 2019 10:02 PM UTC
  • 82 views
apence231
Forum|alt.badge.img+10
I noticed in the applications and formats supported page that AutoCAD Object Data tables (AutoCAD Map 3D) are not able to read in when using FME Cloud - in my workbench on my desktop this reader works great in getting the additional information stored there so seeing if there is an alternative or workaround in being able to get that data while using FME Cloud
itsmatt
Forum|alt.badge.img+48
  • Sep 10, 2019 2:38 PM UTC
You could try the Civil 3D Reader. I want to say that it has some capabilities of reading object data. At least worth a test?
apence231
  • Sep 10, 2019 6:11 PM UTC
That would be great if there is a way to use the Civil 3D Reader since I'm already using that one in the workflow - I checked it out today and not sure if I'm missing anything but still not able to see those additional notes. Any hints on how to see the annotation fields with the Civil 3D reader?
