Attribute Creator - Adjacent Feature not populating more than 1 record
bkerr
I am using the attribute creator to populate a new field. I want to fill in the blank rows with the previous master property number from the master prop no field. I have enabled the adjacent features but no matter what I try it still only populates just the 1 record after a value and not all the blanks. I thought I would only need 1 based on what I’ve found on the forums.
What am I doing wrong here?
I also tried to do that same thing via the attribute manager but get the same result.
The end result would also have row 3 (FME row id not the xlsx one) with ‘932590’ and row 6 with ‘933123’ and rows 9-11 with ‘933796’ etc with the number of blank rows varying from 1 to potentially hundreds.
The settings I have for the transformers are below.
I am using FME 2022.2.
Thank you!
Belinda
Best answer by takashi
HI ​@bkerr ,
If “master_prop_no_calc” is a new attribute that will be created in the AttributeCreator, expose its name with AttributeExposer beforehand.
Then, in the AttributeCreator, I think this conditional value setting works as expected.
If master prop. no. has a value then master prop.no.
Else feature[-1].master_prop_no_calc
crutledge
Forum|alt.badge.img+32
  • May 12, 2025
Hi ​@bkerr This question just came up and ​@takashi caught the issue. In the first case: If there is a value then No Action. Else -1
Fill in adjacent empty values in table is not working as I expect? | Community
Hope that helps!
bkerr
  • May 12, 2025
Hi ​@crutledge. I did see that post but in my case I’m populating a new field so I need it to take the value over rather than do no action. I did try that but it just leaves me with ‘missing’ values for that top row instead.
crutledge
  • May 12, 2025
Ah ​@bkerr then you will want the part of the solution that I proposed (that didn’t work there but I think works here).
In Your case .test is .master_prop_no_calc
That work?
  • May 12, 2025
HI ​@bkerr ,
bkerr
  • May 12, 2025
Hi ​@takashi ,
That did the trick. I was getting the feature[-1] value from the wrong field. I thought it would of worked from the other but it doesnt. Swapping it to the newly calculated field resolved the issue. Thank you!
crutledge
  • May 12, 2025
@bkerr Good stuff. Glad you got it working! It’s always those little things. :D
