Assign writer coordinate system based on processed input data
  • Oct 18, 2016 11:11 AM UTC
  • 6 replies
  • 170 views
jstanger
I'm required to export some spatial data to AutoCAD. The incoming data exists anywhere in Australia and the exported data needs to be in one of the MGA94 zones. The client refuses the suggestion that they select one of the possible 10 projection zones to correctly reproject the data and claims FME should be able to handle this automatically.
Is there a way to modify the AutoCAD writer coordinate system after the FME workspace has been launched (i.e. after I've started reading in data) so that I can correctly export to the zone that corresponds to the input data?
I can see one way if I can get a transformer to replace the value in a public or private parameter. Is this possible?
  • Oct 18, 2016 11:24 AM UTC
You can leave the coordinate system blank on the Writer and use the CoordinateSystemSetter transformer instead. That way you can e.g. use a Tester on your coordinates to decide on which coordinate system to use.
jstanger
  • Oct 18, 2016 12:22 PM UTC
Thanks David, what will happen if the data pushed to the writer is from multiple coordinate systems? Which coordinate system will the writer choose to reproject the other data to?
jstanger
  • Oct 18, 2016 12:23 PM UTC
Or does all the data pushed to the writer then need to be explicitly reprojected to a single system before passed to the writer?
  • Oct 18, 2016 2:46 PM UTC
I would guess that the first feature to hit the writer will set the coordinate system.
I strongly suggest explicitely reprojecting everything to a single system before sending it to the writer, it will save you a lot a headaches.
daveatsafe
Forum|alt.badge.img+24
  • Oct 18, 2016 4:04 PM UTC
The AutoCAD writer will use the coordinate system of the first feature in to determine the file coordinate system, and reproject all subsequent features to that coordinate system when writing.
Since FME does not currently write coordinate system information to the DWG file (although it can write a sidecar PRJ file), I think the best course would be to choose the output coordinate system using a Published Parameter, so you know exactly which coordinate system the DWG file will be in.
jstanger
  • Oct 19, 2016 6:36 AM UTC
This looks to be the way to proceed. Just need to be careful to reproject all incoming geometry before further processing to ensure you have everything in the correct projection before export.
