Are FME Desktop and FME Server 2021.0.2 compatible with MSSQL Server 2019? Thanks for any reply!
  • May 17, 2021 2:50 PM UTC
  • 114 views
a.wolf
Participant
Best answer by david_r
Yes, it's compatible. Just make sure that you've installed the latest ODBC drivers for SQL Server:
https://docs.microsoft.com/en-us/sql/connect/odbc/download-odbc-driver-for-sql-server?view=sql-server-ver15
This goes for both FME Desktop and FME Server.
  • May 17, 2021 3:06 PM UTC
richardatsafe
Forum|alt.badge.img+11
Additionally FME will try to install FME CLR Types 2012, but if you already have a CLR type of a later version it might not install the 2012 version, and you may have to install the 2012 version manually.
