ArcSDE Geodatabase Locks
Hello, I'm new to FME and have a workbench that does a dgn to ArcSDE geodatabase (SQL Server)  feature class conversion of points.  I have the "drop table" set to "yes" which I assume deletes all the features in the SDE geodatabase before writing to it.  To that end, when I run the workbench, I get the error below.  I can see that the geodatabase has locks from ArcGIS Server (we have three instances of ArcGIS Servers running).  I would have to manually stop each ArcGIS Server instance before running the workbench to get it to run correctly.  Is there a better way to run the workbench and update the data?
Unable to drop the table/feature class 'Bollard'. The error number from ArcObjects is: '-2147215875'. The error message from ArcObjects is: {Table is already locked [aoc_gis.GISADMIN.Bollard]}
A fatal error has occurred. Check the logfile above for details.
Thank you
Steve
fmelizard
Forum|alt.badge.img+19
  • May 2, 2013
Hi Steve,
Some time ago I was also investigating how to run a FME script on a locked ESRI gdb. Unfortunatly the ESRI methodology of locking isnt very flexible or user friendly when interacting with outside applications.
In your situation, with 3 potential lockers, I would look into the possibility of using a versioned  db type, or  scheduale the script to run when locking doesnt takes place (if at all possible).
Cheers,
Itay
  • May 2, 2013
Hi Steve,
rather than dropping the table, consider truncating it instead. That is usually more lock-friendly and would have the same net effect, as long as the table schema is stable (doesn't change between translations).
Also have a look at this fmepedia article that uses an SDEQuerier to update records on a non-versioned SDE Geodatabase feature class, which might give you some further ideas.
David
  • May 2, 2013
David and Italy, thank you for the responses.  The truncate table option seems to be doing the trick!
chris_m
Participant
  • Participant
  • May 3, 2013
Steve,
     Yeah Droping table is the equivolent of deleting the table.  Truncate just deletes the features or rows.
Chris
