ArcGIS Portal instalation requirements for using AGS Portal Feature Writer
  • Jul 26, 2018 1:43 PM UTC
  • 118 views
gertner
Forum|alt.badge.img+12
Hi to all, I didn't find any information about requirements for ArcGIS Server and Portal installation for possibility to publish ArcGIS Feature Service. I mean Hosting, Data Store instalation and so on. Documentation? Thanks.
Best answer by gertner
I will answer myself. For publication using ESRI Portal Feature Service Writer is necessary to have installed:
ArcGIS Server Advanced Enterprise
Portal for ArcGIS
WebAdaptor for ArcGIS
Data Store for ArcGIS server
I have tested it on 10.4.1 version. ArcGIS server must be set as Hosting server (Portal settings).
stalknecht
Forum|alt.badge.img+22
  • Jul 27, 2018 9:04 AM UTC
You don't need any additional installation for using the "Esri ArcGis Portal Feature Service" writer. All options are documented in the help for the writer. If you're question is how to configure Esri Arcgis Portal services then you should look for the ESRI documentation. If you experience any problems using the writer please post them here.
gertner
  • Aug 1, 2018 10:02 AM UTC
Thanks for your reply. I wanted to know what is necessary to install on ESRI side of this process. There is a lot of possibilities how to prepare ESRI infrastructure. I tried to describe it below.
gertner
  • Aug 1, 2018 10:07 AM UTC
Portal for ArcGIS
runneals
Forum|alt.badge.img+32
  • Aug 3, 2018 12:12 AM UTC
Portal for ArcGIS
Here's the official esri documentation on deploying enterprise. I highly suggest using ArcGIS Enterprise Builder if possible to make deployment even EASIER.
