ArcGIS Online Write Error
  • January 29, 2019
  • 16 views
runneals
Forum|alt.badge.img+22
ArcGIS Online Feature Service Writer: Could not connect to server. Check that you are connected to the internet and that no firewall is blocking outbound connections. The error was '("Connection broken: ConnectionResetError(10054, 'An existing connection was forcibly closed by the remote host', None, 10054, None)", ConnectionResetError(10054, 'An existing connection was forcibly closed by the remote host', None, 10054, None))'
Best answer by runneals
Looks like something is getting hung up with the feature service in AGOL.
Solution:
  1. Shut off FME scheduled job
  2. Rebuilt the index on the feature service
  3. Disabled edit on feature service
  4. Enabled edit on feature service
  5. Turned FME job back on
runneals
  • January 29, 2019
Solution:
