ArcGIS database table watcher
  • Mar 13, 2024 12:54 PM UTC
  • 101 views
ingalla
Forum|alt.badge.img+10
Hi All
I am trying to set up a workspace to react when a change is made to an ESRI Enterprise Geodatabase table but cant figure out how to watch for changes on the table.
I could set up a scheduled task to read all of the data and then a change detector to update a further table but that doesn't seem a wise use of resources, particular if there are no changes.
SO any ideas how to watch this database table for changes efficiently??
Regards
Best answer by joepk
I think the described route of scheduling a ChangeDetector is a pretty common route to take when you want to monitor changes in a database. Some other options include:
You can try using the CRCCalculator to calculate a CRC value on your geometries and/or attributes. Then compare the CRC strings instead of the objects themselves.
If you have certain columns that always change (e.g. the geometry column, last_edited_date or an attribute specific to your users’ workflow) you can always only read in those columns to to shave off some resource usage.
If the changes are always deletes/inserts (and never updates) you can try to keep track of the highest ObjectID.
joepk
Forum|alt.badge.img+22
  • Mar 13, 2024 1:36 PM UTC
nielsgerrits
Forum|alt.badge.img+67
Is the question about a file geodatabase?
