ArcGIS Data Distribution demo issue
  • Nov 14, 2012 5:45 PM UTC
  • 56 views
michael
I'm attempting to standup the demo ArcGIS Server data distribution application. I configured the workspace and can successfully run it from Desktop and from the FME Server Web User Interface. However, when I attempt to use the web application itself (arcgis.html), the Step 2: Set Parameters form which is supposed to be dynamically generated based on the REST API is not populating.
For reference, this is what I'm tying to do:
http://fmepedia.safe.com/articles/Samples_and_Demos/Standalone-data-distribution-demo-ArcGIS-Server
Michael
michael
  • Nov 15, 2012 3:59 PM UTC
The hostname variable was changed in the form-request-manager.js, but it was not in the rest-manager.js (which looks like where you copied the above code from). So, I changed it and the form still does not generate.
  • Nov 20, 2012 11:12 AM UTC
You need to make sure the parameters are of the correct type in your workbench script. The javascript functions in the application supports either "LOOKUP_CHOICE" or "LISTBOX_ENCODED". Within the FME workbench the parameter type "Choice with alias" is the same as "LOOKUP_CHOICE".
Try adding an alert in the function called parseJSONResponse (rest-manager.js):
parseJSONResponse : function(inResult) {
alert(inResult);
var jsonDoc = JSON.parse(inResult);
Are you getting a response? If so, are the types correct? No response? It could be some security issue. Can you access the fmerest-url manually? Try configuring the fmerest application to use a default account that have permissions to the REST API and the FME-script you want to get the parameters from (to skip token authentication).
If you are looking at your application in Google chrome or in Firefox, use the debugging tools.
