ArcGIS 10.3 and FME 2015 compatibility problem
  • Mar 16, 2015 11:16 AM UTC
  • 5 replies
  • 62 views
ahmad_saleh
Hello,
After Upgrading  ArcGIS from 10.2.2 to 10.3 FME fails to run any workbench and shows this massage.
“Unable to perform licensing related tasks. Please ensure that ArcGIS is correctly installed
... Last line repeated 2 times ...
|ERROR |
|ERROR |
A fatal error has occurred. Check the logfile above for details”
Is this means that FME desktop 2015 doesn’t support ArcGIS 10.3?? because form the massage it shows that the FME 2015 Do not recognize the ArcGIS 10.3, Have any one upgraded to ArcGIS 10.3 and face the same problem ?
Regards,
Ahmad
  • Mar 16, 2015 12:54 PM UTC
ArcGIS 10.3 has been supported since FME 2014 SP5, see also http://fmepedia.safe.com/articles/Samples_and_Demos/Notes-on-FME-and-ESRI-Versions-and-Compatibility#heading_toc_j_1
Have a look here for some suggestions on how to troubleshoot: http://fmepedia.safe.com/articles/How_To/FME-and-Esri-ArcGIS-Troubleshooting-Guide
David
  • Mar 16, 2015 12:55 PM UTC
ahmad_saleh
  • Mar 16, 2015 7:03 PM UTC
Many thanks Davi,
this is really helpful I I think this is the real issue in my case, but sitll dont know how to solve it, do you have any ideas.
http://fmepedia.safe.com/articles/Error_Unexpected_Behavior/FME-cannot-read-or-write-to-Esri-Geodatabase-license-error-messages
thanks,
ahmad
Hi Ahmad,
It's not a helpful answer but just validation that 10.3 with FME 2015.0 does work. I am running both no problem.
ArcGIS Single User License and FME Floating License
ahmad_saleh
  • Mar 17, 2015 7:51 AM UTC
Hi Matthew,
I am using ArcGIS  server license and  FME Floating License and doesnt work with me. So I would say that there is a problem in the FME 2015 in reading my ArcGIS license even if my arcgis  working probapply
Hi Matthew,
I am using ArcGIS  server license and  FME Floating License and doesn’t work with me. So I would say that there is a problem in the FME 2015 in reading my ArcGIS license even if my ArcGIS is working well on my machine.
Thanks,
Ahmad Saleh
