Any solution for FME Workbench crashing?
  • Jun 21, 2016 10:44 AM UTC
  • 197 views
I'm finding FME crashing every time I try to start it.
Checked in the application event log and I can see an error reported ...
Faulting application name: fmeworkbench.exe, version: 2016.7.19.16178, time stamp: 0x56ecc220
Faulting module name: ig7icd64.dll, version: 10.18.10.4176, time stamp: 0x550c0501
Exception code: 0xc0000005
Fault offset: 0x000000000017325a
Faulting process id: 0x1c84
Faulting application start time: 0x01d1cba8da8e46f7
Faulting application path: C:\Program Files\FME\fmeworkbench.exe
Faulting module path: C:\Windows\system32\ig7icd64.dll
Report Id: 2f81a12e-379c-11e6-b705-74e54352be0f
  • Jun 21, 2016 11:40 AM UTC
I would start with re-installing your current version.
If that does not work, I'd try upgrading to the latest version: http://www.safe.com/support/support-resources/fme-downloads/
Forum|alt.badge.img+63
Another thing to check is whether or not your machine meets the minimum system requirements.
Did you have an older version of FME on this machine before? Did that work ok?
  • Jun 21, 2016 12:18 PM UTC
Hi @steveculshaw, the symptom seems to match this article: Workbench Crashes (Windows 7 with Intel or AMD Graphics Card)
Yeap, looks to be the cause
Checked on the Dell site, as the laptop is a Latitude E5530, and I've got the latest version of the Intel driver, so unless there is a fix to Qt, I'm not running Workbench :-(
