XML templater number format issue
  • Aug 25, 2025 9:27 AM UTC
  • 122 views
eric_armitage
Forum|alt.badge.img+11
Hi
I have an attribute value derived from an Excel sheet. The input attribute name is “Vægt”. FME data type is number(20,2). An example value for a feature is “2.95”. I’m trying to retrieve this value using the xml templater using <Cell><Data Type="Number">{fme:get-attribute("Vægt")}</Data></Cell>
But the output value in the xml is 2.9500000000000002
Could anyone explain why this is happening and suggest a fix? I have tried attribute rounding and changing the input Data Type but nothing seems to work.
Thanks
Best answer by david_r
The reason why: https://support.safe.com/hc/en-us/articles/25407633363981-Floating-Point-Precision-and-String-Formatting-in-FME
Workaround:
Example:
<tag>{fn:round(xs:double(fme:get-attribute("Vægt")), 2)}</tag>
  • Aug 25, 2025 9:32 AM UTC
Workaround:
Example:
eric_armitage
  • Aug 25, 2025 12:05 PM UTC
Thanks David that worked!
