Any cad to shape
Dear All
Converting CAD to shpae , it works only with the CAD that intially used to build the Workbench , when we upload another CAD with different schema , not output prodcued .
Thanks,
gio
Forum|alt.badge.img+15
  • June 11, 2014
I think if your new cad objects spatially obey the processes applied to it in the workbench, they should produce a result.
It's schema, or extended data should not matter.
Therefore i presume the objects do not yield a result in the workbench.
One reason might be the projection.
Or maybe one was in mm and the other in meters?
Or maybe some spatial operation was intended for polygons and now u feed it non-closed lines.
we can only guess as you have no example data or workspace posted.
gio
  • June 12, 2014
..unless you processed them using administrative comparisons...where the schema would matter...
