Alter elevation value in a DWG
  • Mar 13, 2017 2:12 PM UTC
  • 5 replies
  • 79 views
I would like to add 100m to all the elevation values in a DWG file. However, how do I do this if the file contains polylines? I want to add 100m to all the vertices along the polyline.
I am using FME2016 Desktop.
Thanks,
  • Mar 13, 2017 2:18 PM UTC
You can use a 3DForcer before the writer.
  • Mar 13, 2017 2:33 PM UTC
Hi, the Offsetter (Cartesian Coordinate Mode) might help you, if you want to add a certain amount to existing z-coordinate for every vertex.
  • Mar 13, 2017 3:27 PM UTC
Thanks Takashi, the Offsetter works exactly as I would like it.
  • Mar 13, 2017 3:34 PM UTC
Also, is there anyway to extract the vertex X Y and Z values along a line in some sort of list?
jdh
Forum|alt.badge.img+41
  • Mar 13, 2017 3:37 PM UTC
CoordinateExtractor in mode All Coordinates
