AGOL WRITER UPDATES BUT DOESN'T DELETE OR INSERT
  • Aug 29, 2016 8:31 PM UTC
  • 6 replies
  • 169 views
gisgeek
Forum|alt.badge.img+9
I am using the latest FME 2016.1.1. I am trying to update features in AGOL and it updates existing features but it doesn't delete or insert new entries. Anyone know why this would be happening I am stumped. I have my AGOL writer set to UPDATE. Is there a setting somewhere I am missing?
ciarab
Forum|alt.badge.img+10
  • Aug 29, 2016 9:03 PM UTC
Hi @gisgeek you need to set the db_operation for each of your entries depending on whether you want to insert /update or delete a feature. You can do this from the attirbute creator. Check out this article and example workspace it provides the complete solution you can copy
https://knowledge.safe.com/articles/19302/how-do-i-write-updates-to-an-existing-arcgis-onlin.html
itay
Forum|alt.badge.img+19
  • Aug 29, 2016 9:31 PM UTC
Yes that is correct setting the writer as opposed to the writer feature type or features will result in one operation (update) and not in an operation per writer features type or per feature
gisgeek
  • Aug 29, 2016 10:13 PM UTC
I have done this already with my set up. I think it may be AGOL side. I am the owner of the data but I get this message: Its owner may have disabled inserting or editing features bla bla bla. But I have enabled editing in AGOL so not having much luck here. It updates existing values which is cool but no inserts are happening which I need
ciarab
  • Aug 29, 2016 10:29 PM UTC
Did you accidentally change the editing settings in AGOL? There is one there that only allows you up update I think. Though I think the default is Add/update and delete features.
What happens when you only try to add inserts with the writer mode as insert? does it give the same error?
gisgeek
  • Aug 29, 2016 11:09 PM UTC
I managed to get it to write now when I run it again it won't update by changing some settings in AGOL. I get the error code from the server was 1019 and the message was: The specified feature could not be updated or does not exist. The data is dynamic so it is important that it updates but doesn't work when I run the workbench again. I have no idea what a 1019 error code is.
ciarab
  • Aug 29, 2016 11:21 PM UTC
So now you can insert and it's not updating any longer? Did you truncate your original data maybe? Sounds like the error means it can't find a matching objectid on the data in question to perform any updates. I assume you are merging the objectid from the existing feature in agol as you had the update working previously.
