AGOL Feature Writer - FME2020.2.3 - Feature Service parameter via attribute
  • Jul 8, 2021 3:19 AM UTC
  • 48 views
Hi
I am setting up a job to update data in AGOL using FME Desktop 2020.2.3
I am aiming to have a single job which I will publish to our FME Server to refresh the data on schedule.
I have multiple Feature Services to update and am hoping to use a single Feature Writer to update them.
In my workspace I generate the Service ID and am passing through to the Feature Writer Feature Service constraint parameter.
This works successfully when the Feature Writer only updates a single Feature Service however when I try multiple it cannot find the Feature Service, it seems to still connect to the first.
Writer_ParamThe log shows that it maintains a connection to the first Feature Service and does not switch to the second.
Writer_LogAre there any issues with this methodology?
Suggestions for alternatives?
Thanks
wainrt
  • Dec 12, 2023 7:35 PM UTC
Did you ever find a good solution to this problem?
