Adding more logos to PDF
  • Aug 2, 2017 11:52 AM UTC
  • 119 views
geospatiallover
Participant
For some reason I can't add more photos (logos) on my pdf.
My current PDF looks like this:
My PDFPageFormatter settings looks like this.
I have moved that two logo objects around and they never appear on the pdf at all. The location map object, which is created by the workspace using raster and vector data can be moved around anywhere and I don't have to do anything extra to locate the jpeg on the PDF page. I added a rastergeoreferencer after my reader using page units, following a related question but that did not work either. How can I fix this without using Avenza's Mapublisher transformer.
fmelizard
Forum|alt.badge.img+22
  • Aug 2, 2017 4:39 PM UTC
Hi @geospatiallover, are you able to share your workspace? Which version of FME are you using?
geospatiallover
Participant
My issue has gone further south. I cannot recreate the size of my location map as shown on the first picture - anymore using the same workspace that I've been running multiple times a day for the last two weeks. The picture is correct because its created in another featurewriter as a JPEG. For some reason PDF transformers compresses the size. I am getting disappointed because I've even tried to start all over again. My current build is 17291 and my only recourse now is to install build 17539 and then start from scratch.
geospatiallover
Participant
@TiaAtSafe, attached is my FME tempalte.
from-survey-to-mission-folder-broken-with-ffs.fmwt
  • Jan 4, 2018 4:45 PM UTC
@geospatiallover did you find a solution to this?
