Adding header lines to textfiles
  • May 10, 2017 2:19 PM UTC
  • 277 views
femo
Hello,
I am processing data and write the results to Textfiles , using a fanout and the featurewriter.
Now i want to add some headerlines (read and blue) in front of the exported lines (black). Plase, refer to the screenshot.
The red lines are the same for any of the files. Only the blue line consistes of a constant part (file.) and
the filename which is individuel. The number of resulting Textfiles varies.
Any ideas are highly appreciated!
Best answer by itay
Create a new attribute (header) that contains the header in an AttributeManager and create a second text_line_data attribute that concatenates the original text_line_data and the new header attribute.
To place the file name in the new header attribute use the fme_feture_type or fme_basename depending on you input data.
See the attached template.
adding-header-lines-to-textfiles.fmwt
Create an UniqueID attribute (I'd use counter), use AttributteValueMapper to create the lines you require using the ID attribute then remove the UniqueID attribute before writing.
itay
Forum|alt.badge.img+19
  • May 10, 2017 5:47 PM UTC
femo
  • May 11, 2017 9:13 AM UTC
Hi @itay,
nice approach! I added an aggregator because I got initially a header for each line.
Thanks a lot!
itay
  • May 11, 2017 9:58 AM UTC
Hi @itay,
Thanks a lot!
Glad I could help!
