Adding data into a single sheet from multiple sources
  • Sep 22, 2016 11:46 AM UTC
  • 453 views
Hey all!
You all have helped me out a lot last time and today I again came across a problem which is why I'm posting again.
The situation
Basically there is a report that has to be created through exporting data from a database and putting it into an excel sheet. I want to automate this through FME.
So I added in two 'sqlcreators' which grab the neccesary data from the database. In the excel writer I want to write the data into specific columns. The issue is that again its going to stack the data on top of each other. I tried to use a featurmerger but obviously it does duplicating checks and thats not
necessary.
The only thing FME has to do is putting data from 'SQLCreator' in collumns A, B and C and putting the data from 'SQLCreator' into the columns E, F and G without stacking the data.
So how fme does it like this now:
How I want the result
Now I have a solution which is creating a workspace for each sql creator and using the output files of the previous sqlcreator output as a template in the excel writer. I however don't find that a really elegant solution and I'm pretty sure it can be made easier within FME itself.
Is this possible and if so how? I find it hard to find out what function within excel writer does and especially the relation between some functions ( truncate, named range and writer/update/delete functions). I have a feeling the magic is somewhere within the writer functions but where and how?
  • Sep 22, 2016 12:17 PM UTC
Hi @adriaan, this might work.
Use the Excel column names (A, B, ...) as user attribute names, and specify the line number (1-based integer) by a feature attribute. e.g. named "row_id".
Then set the writer feature type parameters like this.
pratap
Forum|alt.badge.img+12
  • Sep 22, 2016 12:24 PM UTC
Additionally use counter transformer to generate the row number in sequence based on requirement ( I mean row number in Excel in your example you want from row number 3). If the headers are constant then use excel template option.
itay
Forum|alt.badge.img+19
  • Sep 22, 2016 12:30 PM UTC
Hoi @adriaan,
Do you really need to put all the results in one sheet? it would be a lot easier to map each sql result into a separate xls sheet.
  • Sep 22, 2016 12:38 PM UTC
Supplement. The features from the first SQLCreator should have only A, B, C (i.e. E, F, G, I, J, K should be missing). As well, the features from the second should have only E, F, G, and the features from third one should have only I, J, K. You can then send them to the writer feature type all together.
