Adding appearance to CityGML: color and transparency
  • Jan 23, 2019 6:45 AM UTC
  • 194 views
harmen_kampinga
I like to have a simple shapefile been written to CityGML.
A simple task, I assumed, but it doesn't work out the way I want... at least, not in the end.
The color and the transparency don't come with the CityGML file. What am I doing wrong or what am I missing here?
Attached the Workspace and the data.
itsmatt
Forum|alt.badge.img+48
  • Jan 23, 2019 2:22 PM UTC
Yeah this seems pretty undocumented. I've been trying to get this to work, however, nothing seems to do the trick. Perhaps @DaveAtSafe has some ideas? Could it be a bug - seems like this should be automatic like it is with textures.
daveatsafe
Forum|alt.badge.img+24
  • Jan 23, 2019 7:06 PM UTC
Hi @HarmenKampinga,
FME seems to be having a problem writing the color appearance to solid geometries. I have created a problem report for our development team, and will notify you as soon as this is fixed.
In the meantime, please use a GeometryCoercer after the Extruder to convert the geometry to fme_composite_surface. This will produce a CityGML file with the desired appearance.
itsmatt
  • Jan 24, 2019 8:14 AM UTC
Hi @HarmenKampinga,
Thanks Dave!
harmen_kampinga
Hi @HarmenKampinga,
Thanks Dave! I will use your suggestion for now
