Adding 3 consecutive records
  • Feb 21, 2018 3:29 PM UTC
  • 103 views
We 100+ years of rainfall data that we would like to find 3 consecutive days where the rainfall is greater than 50mm after a certain date. I can do this in Excel but I can't for the life of my figure out how to do it in FME. Does anyone know if it is possible?
In excel adding three consectutive days rainfall is pretty simple =SUM(F2:F4) and fill down the column.
Cheers,
Dale
Best answer by david_r
You can use the AttributeCreator with the adjacent feature option, e.g.
  • Feb 21, 2018 3:34 PM UTC
gio
Forum|alt.badge.img+15
  • Feb 21, 2018 5:17 PM UTC
you can also partition the data by creating an attribute conditionaly >50mm = yes
Then a counter on that attribute. Statistics grouped by that and get max value.
Test if >3
  • Feb 21, 2018 10:51 PM UTC
Hi David,
That worked! Thank you so much!! I knew it had to be doable in FME.
Thanks,
Dale
fmelizard
Forum|alt.badge.img+22
  • Feb 23, 2018 4:11 AM UTC
Hi David,
Thanks,
Dale
PS: I like your name! Not too many of us around, let alone in the FME community!
