Accessing published workbench from client machine,
  • Sep 24, 2014 9:34 AM UTC
  • 36 views
jamal
Forum|alt.badge.img+5
I have published simple workbench that converts CAD files to shape files but couldn’t figure out how this workbench can be used from the client side.
The link below doesn’t work from the client side
http://10.110.62.82:8080/fmedatastreaming/Samples/CAD_TO_Shape.fmw?SourceDataset_GENERIC=%24(FME_MF_DIR)Ayman_02.dwg&FEATURE_TYPES=Parcels_Geometry&DestDataset_SHAPE=D%3A%5CS1
What might be the issue here?
Thank you
Best
Jamal
  • Sep 25, 2014 12:14 PM UTC
here's a couple of excellent starting points:
API playground: http://playground.fmeserver.com/ Use the debugging functionality of your browser to intercept and analyse the calls to see how it's done.
REST API doc: http://docs.safe.com/fme/html/FME_REST/#
David
jamal
  • Sep 25, 2014 4:13 PM UTC
Many thanks David,
Unfortunately, I can’t find useful information from the links you have already provided.
The local IP of my server machine is 10.110.62.82 while the real IP is 213.6.3.172. Now, as any workbench is published, then the local IP (10.110.62.82) is generated in the link.
From where I can set the FME Server to take the real IP instead of the local IP?
