Accessing FME Cloud resources files
  • February 25, 2015
  • 8 replies
  • 31 views
fmelizard
Forum|alt.badge.img+19
I would like to know if anybody has any experience on how to access files on an FMECloud instance. To clarify a bit, I have a xls file in a folder in the resources section that I would like to access in mid-translation via FME desktop. The idea is to verify details that are on the xls file before continuing with the translation.
I was thinking on using the HTTPCaller, but couldnt access the resources section on the instance.
Any tips would be appreciated.
Itay
Best answer by david_r
No sure if the shared resource files are directly accessible via HTTP on FME Server. But you could of course publish a simple workspace on the cloud that returns your resource file over HTTP.
David
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • February 25, 2015
there are a couple of published parameters available on FME Server to access the shared resources:
  • FME_SHAREDRESOURCE_TEMP
  • FME_SHAREDRESOURCE_DATA
So if you upload "myData.xls" into the Data resource section on FME Server, you can access it with e.g. a FeatureReader using $(FME_SHAREDRESOURCE_DATA)/myData.xls
You can also create subdirectories in the shared resources to organize your files.
David
fmelizard
  • February 25, 2015
Hi David,
Thanks for the info, unfortunatly this wil only work if the ws is run on the instance, I would like to run the ws locally and access the files.
  • February 25, 2015
Then I would suggest using a scripted parameter that checks if FME_SHAREDRESOURCE_DATA exists. If not, you could return FME_MF_DIR instead, which is the directory where the workspace is saved.
David
fmelizard
  • February 25, 2015
The FME_SHAREDRESOURCE_DATA would not exist since it is run locally, and the FME_MF_DIR is not an option since I dont want to make the file locally available.
If it would just be possible to access it with an HTTPCaller.....then I could query the contents in midtranslation, is it at all possible?
  • February 26, 2015
David
fmelizard
  • February 26, 2015
and I did just that, thanks for setting me on the right path....
sigtill
Forum|alt.badge.img+24
  • February 26, 2015
What about using the FMEREST API to download the resource via the HTTPCaller?
http://docs.safe.com/fmerest/v2/resources/FME_SHAREDRESOURCE_TEMP/filesys/foo/bar?detail=low
fmelizard
  • February 26, 2015
Hi SigTill,
If I understand you correctly that will result in a local copy of the resource file, something I am trying to avoid.
I followed David's suggestion and created a ws that is registered to the data streaming service. Now I can access the online file without a local copy.
