ACAD DWG TO ACAD DXF
  • Mar 29, 2018 12:12 PM UTC
  • 64 views
mamajid
AutoCAD DXF files created by FME are larger than those produced by other software packages. How we can reduce that. I have many dwg files to convert to DXF. Thank you
pratap
Forum|alt.badge.img+12
  • Mar 31, 2018 9:56 AM UTC
I have not observed the size of the file... Could you please post dwg and dxf file which you have observed.
Pratap
Hi majid,
Consider working with a transformer called Scaler.
Maybe it help us change the vizualization.
Are there also distortions of area measurements?
Inovacao
lars_de_vries
Forum|alt.badge.img+10
There is an option in the Writer parameters to purge the drawing after writing. I expect that would help to reduce the file size. At last I guess that is what you refer to with the files being larger.
