A compatible ArcGIS Python within the supported range could not be found
  • May 24, 2019 12:55 AM UTC
  • 8 replies
  • 131 views
I have installed ArcGIS Pro 2.3.3 which uses Python 3.6 with FME Desktop 2019.0.1.0 64 bit
FME log is returning error in the title with FME Translation Settings:
Preferred Python Interpreter:
ESRI ArcGIS Pro 2.1/2.2/2.3 Python (3.6)
ArcGIS Pro is licensed to work offline.
Any suggestions to get this working appreciated.
Best answer by tfsrichard
Support helped me find the all important missing setting as below.
Originally set for Python 2.7
  • May 27, 2019 7:44 AM UTC
Can you please post the FME log with all the error messages.
  • May 27, 2019 10:30 PM UTC
Thanks David,
Please find attached.
entgdb_daily_maintenance.txt
  • May 28, 2019 7:14 AM UTC
Look at the official support page for FME and ESRI compatibility:
https://knowledge.safe.com/articles/1517/notes-on-fme-and-esri-versions-and-compatibility.html
As far as I can tell from this page, ArcGIS Pro is only supported up until version 2.2. Your version 2.3.3 is therefore unfortunately not yet supported.
runneals
Forum|alt.badge.img+32
  • May 28, 2019 4:59 PM UTC
Do you have 32 or 64 bit FME installed? We are running 2.3 on server 19253 and it works fine.
  • May 28, 2019 9:56 PM UTC
64 bit FME Desktop
  • May 28, 2019 11:46 PM UTC
I uninstalled ArcGIS Pro 2.3.3 then installed 2.1 with the same result.
  • May 29, 2019 11:44 PM UTC
trentatsafe
Forum|alt.badge.img+7
just to confirm @tfsrichard, was your question answered?
