3DAffiner: Add additional z-values
  • Apr 25, 2017 2:01 PM UTC
  • 86 views
Is it possible to add extra z-value to a point cloud (las) with 3D affiner? I need to add extra 0,507m to my already existing z-values. I'm changing from a local to an national height system but i don't know the parameters from the local one.
regards,
Anton
Best answer by jdh
If you have a consistant value to add, you can simply use the Offsetter
jdh
Forum|alt.badge.img+41
  • Apr 25, 2017 2:17 PM UTC
gio
Forum|alt.badge.img+15
  • Apr 25, 2017 2:24 PM UTC
@antonlarsson10
He means yes you can use 3d affiner too..
1,0,0,0
0,1,0,0
0,0,1,Zvalue +value to add
Used offsetter and it worked great!
Thank you,
Anton
