3d Studio Max
  • Jan 12, 2018 2:07 PM UTC
  • 60 views
sigtill
Forum|alt.badge.img+25
Anyone have some tips working with FME moving detailed buildingdata to and from 3D Studio Max?
https://www.autodesk.com/products/3ds-max/overview
whkarto
Forum|alt.badge.img+14
  • Jan 15, 2018 7:30 AM UTC
What excatly do you mean by "detailed building data"?
The most important advice I can give to you is to keep your data lcated around 0/0/0. 3D Studio Max is based upon single precision, which meant that you'll have a precision of slightly better than 1 mm at a maximum distance of 10 000m from axis-origin. Data that exceeds this limit will be permanently rounded by 3D Studio Max! So use an Offsetter in FME to avoid this issue!
A suitable container for transferring data from FME to Max ist the FBX format, which is an interchange format produced by Autodesk to enable data exchange between 3D programs.
