3D shape to obj format
  • Nov 22, 2018 5:06 PM UTC
  • 5 replies
  • 343 views
I have a 3D polygons file that I would like to convert to obj format. I tried several times but I always have one polygon in the output that is strange.any advice or idea?
thanks!
chrisatsafe
Hi @irene2018,
It looks like you might want to use a Fanout in this case. For example, in the linked workspace there are six 3D polygons in the shapefile so I am fanning out based on the Neighbor00 attribute. This will write out 6 OBJ files, one for each neighborhood polygon.
Fanout:
https://www.screencast.com/t/dGpN26CcUwhttps://www.screencast.com/t/CejPg24Vu
Single OBJ:
https://www.screencast.com/t/sQ8DsI30sJ
https://www.screencast.com/t/Z4aLTY1WAZ
esrishape2obj.fmwt
  • Nov 23, 2018 5:04 PM UTC
Following your advice:here is what I have,is that correct?
chrisatsafe
Hi @irene2018,
Is the output geometry your desired output? It looks like there are multiple polygons instead of a single polygon.
If it is not, are you able to attach your workspace and go into more detail about your desired output?
  • Nov 27, 2018 10:34 AM UTC
Hi @ChrisAtSafe ,it seems that it is the definition of yaxis up or z axis up that needs to be set ,but I cannot find the option
chrisatsafe
@irene2018 - It doesn't look like there is anything in the OBJ Writer Documentation for defining y/z axis but perhaps the CoordinateSwapper could help? This transformer allows you to swap y & z coordinates if they are not in the xyz format (as specified on the Supported OBJ File Syntax doc).
