3D PDF units?
  • Jun 2, 2020 12:42 PM UTC
  • 131 views
itsmatt
Forum|alt.badge.img+48
Hi All,
Just been playing around with the 3D PDF writer and have noticed that my output seems to be in mm rather than meters (AdobeReader has a measurement tool)
I've turned off "Move to local Coordinate System" but the issue is still there. Is there a way to specify the unit in the writer? or is the only way to do this to scale the model so that the measurements are at least accurate?
fme-phile
  • Jun 2, 2020 1:58 PM UTC
hI @virtualcitymatt
Open the PDF
Right click on the image
Click on '3D Preferences'
Click on 'Measuring (3D)' located under 'Categories',
Tick 'Use default display unit:
Change the unit to 'Meters'
Click OK
itsmatt
  • Jun 2, 2020 3:41 PM UTC
hI @virtualcitymatt
Open the PDF
Click OK
Thanks for the tip - I tried that but seems like it only converts the mm into meters for display purposes - My measurements are now 0.001 m when they should be 1 m.
kailinatsafe
Forum|alt.badge.img+24
Hi @virtualcitymatt! We looked this up in our system and found an existing issue FMEENGINE-38044. Unfortunately, there is not a work around we know of, but we will update this post as soon as the status changes.
itsmatt
  • Jun 8, 2020 6:07 AM UTC
Thanks for the update!
