3d object in postgis
  • May 4, 2018 11:44 AM UTC
  • 53 views
robert_punt
Forum|alt.badge.img+9
Hello everybody,
I have a building in 2d and i use a 3dforcer to create an 3d building (walls collums doors rooms...) but i want to write it to postgis. when i use the datainspector to look at the postgis data i can't see anything
How can i store the 3d object in postgis?
Forum|alt.badge.img+63
If you just use the 3DForcer you don't actually create a 3D building, you're just putting the building contour at a certain elevation, it will still be a single plane. Try the Extruder instead.
robert_punt
  • May 4, 2018 12:44 PM UTC
i am sorry. i use the extruder
I lift my building for each floor with the 3dforcer and then i use the extruder to extract de floor to a bsolid.
fmelizard
Forum|alt.badge.img+22
  • May 4, 2018 3:59 PM UTC
Hi @robert_punt, are you able to see the data in pgAdmin?
robert_punt
  • May 5, 2018 6:06 PM UTC
@TiaAtSafe in the PgAdmin i can see the data.
