Excel color tab
alc33
Forum|alt.badge.img+10
Hello!
I would like to have a color in a tab when I write an excel file. I don't find the solution on the excel writer parameters, or excelstyler. I would prefer not use template file.
Thanks!
Best answer by danilo_fme
Hi @us - I suggest you try to use python script after you write your excel file.
Like this: transformer FeatureWriter to generate your excel file and after the transformer FeatureReader to extract the excel file generated before and use a PythonCaller to style your Excel file.
https://xlsxwriter.readthedocs.io/example_tab_colors.html
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+45
  • June 26, 2019
Thanks,
Danilo
alc33
  • July 8, 2019
Hi!
Thanks, I will look this solution.
