TesseratCaller partially broken - potential fix
  • April 15, 2025
  • 14 views
andrej
Forum|alt.badge.img+3
The TesseractCaller appears to be partially broken at the moment. It sometimes doesn’t return all words from the OCR process and the results aren’t transformed correctly to fit on the page. I suspect that this is the results from Tesseract having been updated since the release of the transformer. See the images below as documentation. Where the existing TesseractCaller produces 38 word results from my input image and the fix produces 81. (This difference is the result of a listexploder rejecting features not containing a list, so nothing has been changed about how FME interacts with Tesseract) The results are also correctly flipped and scaled in FME to match the input image. I have supplied the fixed transformer as a zip to this post.
Differences:
Before, text is missing, scaled incorrectly and flipped from the image
After, all text is included and correctly aligned with the image
hkingsbury
Forum|alt.badge.img+55
  • April 15, 2025
Nice work ​@andrej!
To make sure the correct team at Safe see this, probably worth opening up a support ticket and linking this thread
