EXTRACTION dgn vers shp
kanteyemaodo
Forum|alt.badge.img+5
 j'ai un fichier dgn contenant les câbles de type polyligne avec leurs extrémités. -je veux extraire les câbles et les convertire en shapefile (.shp) avec les noms des extrémités.
danilo_fme
Forum|alt.badge.img+45
  • February 11, 2025
Hi ​@kanteyemaodo
I suggest you use the attribute of format in your Writer (fme_basename).
Thanks in Advance,
Danilo
kanteyemaodo
  • February 11, 2025
Yes I'm talking about the extraction of cables and lights. The output format will be Shapefile
danilo_fme
  • February 11, 2025
Please, could you share me your data?
kanteyemaodo
  • February 11, 2025
Here is the dgn. I want to retrieve the ends of the cables and extract them.
danilo_fme
  • February 11, 2025
Please ​@kanteyemaodo
kanteyemaodo
  • February 12, 2025
@danilo_fme
Thank you very much.
but the data doesn't come out after the GeometryFilter?
kanteyemaodo
  • February 12, 2025
@danilo_fme
the error :
The encoded string is not a valid UTF-8 : dgn_coordinate_system_name_Par d\xE9faut’
Note : The cuurent process encoding is ‘UTF-8’
danilo_fme
  • February 12, 2025
kanteyemaodo wrote:
@danilo_fme
Hi ​@kanteyemaodo
For this Feature is without transformer GeometryFilter and the result was done (poygon). As you can see:
Thanks in Advance,
Danilo
danilo_fme
  • February 12, 2025
kanteyemaodo wrote:
@danilo_fme
the error :
Please - share me the full log file.
kanteyemaodo
  • February 12, 2025
When I use the GeometryFilter transformer or another transformer, I get this error message as an attachment.
I want to read the dgn, then extract the cables (polylines) .shp with the names of the ends (points).
kanteyemaodo
  • February 12, 2025
@danilo_fme any way to convert .dgn file to UTF 8??
