Navisworks Reader – GUID attribute not preserved when reading NWD/NWC files
  • Apr 30, 2026 4:24 PM UTC
  • 92 views
edualarcong
Forum|alt.badge.img+5
Hello FME Community,
When using the Navisworks Reader, I encounter a constant issue when trying to preserve the element GUID as a feature attribute. The GUID attribute is exposed by the reader, but some values return a string of zeros (e.g., 00000000-0000-0000-0000-000000000000) even though those same elements display a valid GUID in Navisworks. This seems to occur for elements originating from certain authoring tools, such as Tekla.
The GUID is a 128-bit unique identifier assigned to every element in a Navisworks model. This value serves for element traceability.
Is there a workaround for correctly extracting this value?
danilo_fme
Forum|alt.badge.img+58
  • Apr 30, 2026 5:12 PM UTC
Hi ​@edualarcong
Please, could you share a sample of this data?
Thanks in Advance/Gracias,
jovitaatsafe
Forum|alt.badge.img+11
Hi ​@edualarcong,
Thanks for raising this for us and submitting a case! This is sort of a duplicate message for you, but for anyone else who runs into this, I've filed a problem report tracked internally as (FMEENGINE-98073). I’ll be back to this thread (and I’ll notify you through your case as well), when the issue has been addressed.
Sorry for the inconvenience!
