Missing parameter STREAM_JOB_KEY_TTL FME Flow 2026.2
  • Jun 25, 2026 9:55 AM UTC
  • 118 views
svenr
Forum|alt.badge.img+12
I get this error message in the system events log:
Event Description: Triggered whenever a warning message is logged to fmeserver.log.
Event Title: Warning Message Logged
Message: Parameter STREAM_JOB_KEY_TTL missing from config file. Using default value of: 60
FME Flow 2026.2 Build 26333
Any hint where i can set the parameter?
timatsafe
Forum|alt.badge.img+8
  • Jul 8, 2026 8:53 PM UTC
Hi ​@svenr ,
Is this happening for all warning messages when running jobs or just when running a specific workspace? Where are these warnings coming from? Is this from a Stream, Automation/Run Workspace? Do you know when this started to occur?
svenr
  • Jul 9, 2026 4:34 AM UTC
Hi ​@timatsafe ,
this seems to happen when a job finishes. For all jobs in schedules and automations.
We get the messages in FME Flow 2026.2, in 2025.2 we had no error messages.
timatsafe
  • Jul 14, 2026 10:51 PM UTC
Hi ​@svenr,
If you can please submit a ticket so that our team can look into this further, that would be great!
When submitting your ticket, please provide the following (if available):
- Details about the environment used (e.g. platform and OS version, FME Flow deployment, any other dependencies, etc.)
- Any relevant log files (e.g. translation logs, job logs, fmeserver.log, etc.)
macatsafe
  • Sep 15, 2026 4:29 PM UTC
Hi ​@svenr,
New update regarding this:
This system event affects FME Flow 2026.2 and later. It is only log noise and does not indicate a security threat or a problem with the system. We aim to address this in 2026.3.
To suppress the message for now, add STREAM_JOB_KEY_TTL=60 to fmeFlowConfig.txt, save the file, and restart the FME Flow services. This setting preserves the existing behavior while preventing the warning from appearing in the logs.
