How to email an attachment with dynamic name in FME Automation
  • Oct 22, 2026 1:34 PM UTC
  • 66 views
marias
Forum|alt.badge.img+11
I have a simple FME Flow automation:
Trigger → Run workspace (generates excel report) → Emailer
Generated excel doc has dynamic name with the date: Reprot_YYYYMMDD.xlsx
I know how to email attachment with the stable name but can’t find the way to attach document that always has different name. Because in Action block and in Emailer block0 I need to specify Destination Microsoft Excel File and Email Attachment.
Could you please advise if this is possible and how. Thanks!
FME Flow version 2025.
Forum|alt.badge.img+54
  • Oct 22, 2026 2:34 PM UTC
If you add an automations writer to your workspace, you can send the name of the generated excel file to the automations writer. Then you will have the name available to you to use in the emailer.
zoe.forbes
Forum|alt.badge.img+10
  • Oct 23, 2026 12:58 AM UTC
Hi ​@marias, thanks for your post! ​@ebygomm’s approach is the one I’d recommend, here are full instructions:
  1. Write out the Excel file to FME_SHAREDRESOURCE_TEMP. I used the @DateTimeNow() function to quickly test dynamic file naming.
  2. Use an AttributeKeeper to retain just the _dataset attribute.
  3. Use an Automations Writer to pass this to Flow.
  4. Create an automation similar to the one below. In the Email action, reference the parameter here:
 Please let me know if you have any questions!
marias
  • Oct 23, 2026 1:02 PM UTC
Thank you! It was helpful, I’ve discovered the new transformer.
marias
  • Oct 23, 2026 1:03 PM UTC
Hi Zoe, thanks for the extended reply. I’ve managed successfully complete my automation.
