Question of the Week: Tips & Tricks You Wish You Knew Sooner...
  • Nov 18, 2025 8:18 PM UTC
  • 8 replies
  • 251 views
creeatsafe
Forum|alt.badge.img+16
There’s always more to uncover in FME. From sneaky shortcuts to powerful features, it’s full of “why didn’t I know this sooner?” moments! 💡
This week’s Question of the Week:
💭 What’s an FME trick or shortcut you wish you’d known sooner? If another Community member showed you this trick - tag them in the comments!  😊
💡 New to the Question of the Week?
Each week, we post a simple but thought-provoking question. It could be about your FME journey, the power of spatial data, FME innovation, or even the future of FME.
Every answer you share earns you an entry in our monthly draw for exclusive Safe swag (a $50 value) — plus points toward community badges!
🗓️ Answer all of November’s Questions of the Week by November 30, 2025, at 5:00 PM PST to be entered into this month’s draw.
🎖️ Answer your first question to earn the Socializer (Ice Breaker) badge — and keep it up to reach the Socializer (Talker) badge after five answers!
hkingsbury
Forum|alt.badge.img+73
  • Nov 19, 2025 12:33 AM UTC
Keyboard shortcuts!
ctrl+k for annotations
ctrl+b for bookmarks
ctrl+e to enable/disable
ctrl+shift+j for jucntions
ctrl+shft+i for inspectors
I’m sure there’s more that I use and don’t even think about!
geomancer
Forum|alt.badge.img+71
  • Nov 19, 2025 6:30 AM UTC
Giving color to (hidden) connections.
mark2atsafe
Forum|alt.badge.img+59
  • Nov 19, 2025 10:55 PM UTC
Pressing the <alt> key when moving an object shifts the quick insert point to the other side. Just a little tip to make it easier to drop transformers into the correct position more easily.
Forum|alt.badge.img+63
The Feature Connections window continues to amaze people 😄
Forum|alt.badge.img+54
  • Nov 20, 2025 10:11 AM UTC
Transformer Presets
  • Nov 20, 2025 10:14 AM UTC
Expanding on this, applying a connection style to upstream/downstream connections
danilo_fme
Forum|alt.badge.img+58
  • Nov 29, 2025 7:15 PM UTC
Hummm interesting and curious question.
ctrl+k for annotations is very interesting and fast!
j.botterill
Forum|alt.badge.img+69
  • Nov 30, 2025 7:14 AM UTC
When you want to merge every feature from one stream with every feature from another, regardless of attribute values
Union - Feature Merger 1=1
Compared to other join conditions (like matching on a key attribute), "1 = 1" ignores attribute values and simply joins everything. Be cautious: with large datasets, this can create a huge number of output features
