workspace management
  • Jan 14, 2025 1:47 PM UTC
  • 95 views
fmesafe.podpora
Forum|alt.badge.img+11
Hey. I need some directions, please. I currently have several workspaces that I need to run chronologically. They are workspaces that process data, and they include WS that perform operations on the database. What is important is that each subsequent workspace is run based on the previous ws running correctly. My idea would be a sort of queue where each succesfly status of the previous ws would trigger the ws following it. This whole thing should then run on the server. Maybe a workspacerunner? Or something else?
Thanks
  • Jan 14, 2025 2:22 PM UTC
Have you considered using a Flow Automation for this? It makes it really easy to chain workspaces depending on their success or failure.
fmesafe.podpora
Hey. I was considering. Do you think it's better than solving with one master workspace, for example using the mentioned workspacerunner? I get the feeling from the server part of Flow automation that it is more suited for triggering. Can you please give me an idea how you would handle this on an FME server?
