Why we can't transfer file via sftp using planned actions. And why we can transfer manually using the same script.
  • Feb 14, 2022 3:57 PM UTC
  • 104 views
We have a script in FME Engine Linux FME Server 2021.0.1 Build 21313 - linux-x64
itsmatt
Forum|alt.badge.img+48
  • Feb 17, 2022 11:35 AM UTC
Yeah this is pretty weird - can you take a look at the FME Server Process monitor log? This should show the actually errors returned by the smtp call rather than just the error code:
logs>engine>current>fmeprocessmonitorengine.log
  • Feb 18, 2022 12:47 PM UTC
Is there a difference between directory location on Linux and Windows ? Because we are on Linux.
Thanks.
itsmatt
  • Feb 18, 2022 1:50 PM UTC
The path is from the user interface and is the same on windows and linux (for the UI). It could be different in different FME versions though. This is from FME Server 2020.
here's some more info about where the logs are
https://docs.safe.com/fme/html/FME_Server_Documentation/ReferenceManual/About_Log_Files.htm
