Why is the FTP Directory Trigger not working when "Watch Subdirectories" set to "Yes"?
  • December 20, 2022
  • 5 replies
  • 49 views
Hello. Using FME Server 2022. I have an issue monitoring our FTP. I want to monitor all subdirectories for changes. I keep getting an error where "/." is being appended to the "Path to Watch Directory" an infinite number of times. I get thousands of errors from the automation.
SubdirectoriesHere is the error message:
errorWhen I check into our ftp client logs, here is an example of the file path that FME Server creates:
/upload/Directory/./././././././././././././.
Why doesn't the trigger just detect and stop at the directories that exist?
Best answer by siennaatsafe
If anyone else encounters this please note this was found to be a bug and was fixed in our latest FME 2023.0 beta (b23245+): safe.com/beta
keziaatsafe
Forum|alt.badge.img+7
  • December 20, 2022
Hi @dsmylie​ ,
What version and build of FME 2022 are you using? I was not able to reproduce this issue.
How many subdirectories is expected inside /upload/Directory?
Would you be able to share the ftp log and the automation log for me to take a look?
Thanks,
Kezia
  • December 20, 2022
Would it be possible to share this information with you directly? I don't feel comfortable sharing the ftp log, especially on a public forum. Cheers!
  • December 20, 2022
keziaatsafe wrote:
Hi @dsmylie​ ,
Thanks,
Kezia
Here is the information I am comfortable sharing:
FME Server 2022.1.2
Build 22627
Number of subdirectories ~200.
keziaatsafe
  • December 20, 2022
Hi @dsmylie​ ,
Yes, absolutely! Please submit a case here: https://community.safe.com/s/submit-case .
For more details see How to Create a Great FME Server Support Case.
Thanks!
Kezia
siennaatsafe
Forum|alt.badge.img+11
  • March 9, 2023
