Use FME Flow parameters in FME workspace
asablomberg
Forum|alt.badge.img+7
Hi! I have an automation with an email trigger, and I want to use the emails subject in the FME Form workspace, how do I do that?
Best answer by redgeographics
You’ll need to create a User Parameter in your workspace and then in the automation you can use the Event Attributes to fill that parameter
Forum|alt.badge.img+50
  • August 1, 2024
smclaugh1
  • August 1, 2024
Do you have to parse an email trigger like you do a webhook?
No, at least not if you only want to use the information that’s being put in the Event Attributes.
