Substract overlaps after a buffer operation
  • May 24, 2013 8:39 AM UTC
  • 5 replies
  • 83 views
Hi, I find a way to substract ALL overlapping polygons after a buffer operation from lines. Has anyone a solution? Thanks in advanced!
Forum|alt.badge.img+54
  • May 24, 2013 8:49 AM UTC
Area on area overlayer and then test for overlaps >1
  • May 24, 2013 8:51 AM UTC
Posted too soon, you only want the attributes that pass through the failed port.
  • May 24, 2013 8:56 AM UTC
The AreaOnAreaOverlayer transformer might help you.
This transformer splits input areas into overlapped parts and non-overlapped parts. And each output feature has the overlap count attribute (named _overlaps by default), so you can test if the feature has been overlapped or not.
Takashi
  • May 24, 2013 9:00 AM UTC
Responses overlapped :-)
  • May 24, 2013 10:11 AM UTC
Thanks to you! I did it with Buffer + AreaonAreaOverlay + AttributeRangeFilter!
Have a nice day! Cheers
