Small change to workspace, republish to FME Server, affects Automation?
  • Mar 2, 2021 5:39 PM UTC
  • 163 views
sdepriest
Forum|alt.badge.img+9
Do I need to refresh the "Run Workspace" action in an Automation on FME Server when I make an expression change in an Attribute Manager in the workspace? I've published the updated workspace to FME Server already. Will the Automation run the newest version of the workspace? Or do I need to make it "see" the change somehow?
Best answer by itsmatt
No, you shouldn't need to. Republishing the workspace will simply overwrite the existing workspace and all automations which use that workspace will now run the new workspace. The new version will be used in place of the old version as long as the name of the workspace it the same.
itsmatt
Forum|alt.badge.img+48
  • Mar 3, 2021 1:37 AM UTC
sdepriest
  • Mar 3, 2021 2:06 PM UTC
Thank you for the clarification. 🙂
