retrieve last used oid value and set counter to start with next number. Postgres 14/PostGIS oid
  • July 31, 2023
  • 43 views
gisbradokla
Forum|alt.badge.img+17
I am writing to postgres/postgis st_geometry in an autmation that is loading many dwg datasets. (runs workbench on each dwg)
The postgis writer shows that ver 14 ignores writing od.
I need to get an oid calculated beginning with the last oid used (in the previous automation)
NOTE: postgis writer specifies that oid is ignored at postgres 14.
I tried just using a counter and hoped that writing to existing would automatically write the oid. (I get an error the oid already exists).
I am using this oid as the primary key so that It doesn't have to be set when adding to esri.
I have attempted to read the flat postgres table and sample the last n and then use that as a parameter to set the start number of the counter. But have not been successful getting that to work.
imageAny ideas on how to do this?
virtualcitymatt
Forum|alt.badge.img+36
well, if your oid's are always sequential (that is the highest number is the most recent) then you can use this call inside an SQLExcecutor to get the last row.
SELECT * FROM "<table_name>"
ORDER BY "oid" DESC
LIMIT 1;
This should give you the last record from the table. From there you can use a counter starting from the oid value (or oid+1 ).
