REST API Cannot upload files
  • Jan 22, 2025 12:30 PM UTC
  • 282 views
johannafalk1
Forum|alt.badge.img+20
Hello community,
I am currently facing problems uploading files to FME Flow. Previously I was handling this with a “FMEFlowResourceConnector”. One of our instances was now updated to version FME Flow 2024.2 (Build 24783 - win64).
As the transformer “FMEFlowResourceConnector” was deprecated in FME 2024.1.0 (and it anyway refused to work with the transformer) I tried to go directly through the Flow REST API with a POST request.
My request:
/fmerest/v3/resources/connections/{connection}/filesys/{path}
In my concrete example:
/fmerest/v3/resources/connections/FME_SHAREDRESOURCE_DATA/filesys/Test
I get this as a response:
"message": "Error communicating with FME Flow host XXXXXX.\nContact your FME Flow administrator who can investigate the log files for further details.\nAlso see: http://fme.ly/e100007#error-communicating-with-fme-server-hostConnection refused: connect"
However, when I try the same approach on my local installed Flow (same version), it works using this POST request.
Does anyone have an idea, what could be the problem?
Unfortunately I couldn’t find anything useful related to the error message above.
I also tried with v4, and there I also cannot even make it work on my local machine.
This is my request:
fmeapiv4/resources/connections/{connection}/upload?overwrite=false&path=%2FTest
Response:
"message": "The required parameter \"files\" was not found in the request."
Thanks for your help!
johannafalk1
  • Jan 31, 2025 7:27 AM UTC
Restarting the services solved the problem.
