Resource or Network Directory (updated) delay
  • Jun 8, 2026 9:53 PM UTC
  • 10 replies
  • 124 views
navid.fotovaty
Forum|alt.badge.img+4
Hey guys,
We are on FME Form and Flow 2026.
I have a Form which generates an email, and I have a Flow Automation that using the “Resource or Network Directory (updated) delay” trigger my Form.
I am facing an issue. The directory that I am watching will always gets update with three different files, this means, my Flow runs my Form three times and three separate emails gets generated with the same content.
I am unable to change the directory where files are located, since the files that get generated are from am older system that I can’t touch.
Is there anyway to add a delay to the Flow? or to the Form that stop the system from running three times?
Thanks
Best answer by ebygomm
The options are on the run workspace action
Forum|alt.badge.img+54
  • Jun 9, 2026 8:18 AM UTC
Do you mean you have an automation that triggers a workspace?
navid.fotovaty
Yes, I do, it runs every 5 minutes and monitor the folder for activity. If it detects activity, it will run the workspace.
  • Jun 9, 2026 4:32 PM UTC
If you tick Skip if Job in progress under Advanced settings, the workspace should only be triggered once each time the folder is polled
navid.fotovaty
Hello,
I am using automation, and I don’t see the options you are showing me
  • Jun 11, 2026 1:35 PM UTC
navid.fotovaty
I see now, thank you so much.
I will give it a try and see. The job is usually ran in matter of seconds, Ill keep you posted if this can fix that issue.
navid.fotovaty
This defiantly helped. I got two emails rather than 4 now. They two emails came 5 minute a part, which is the value I have for my trigger to check the folder. Any fix for that part now?
timatsafe
Forum|alt.badge.img+8
  • Jul 8, 2026 9:09 PM UTC
Hi ​@navid.fotovaty
You could also use a Filter Action Node here to have it filter out 2/3 of the files and have it run only when 1 of the files triggers the automation. The screenshot below shows an automation that will only run a .shp is received.
navid.fotovaty
Hi ​@navid.fotovaty
Thanks Tim, but it has been working so far using ​@ebygomm  method. It took couple of days, but its been three weeks, where it only sends one email.
timatsafe
  • Jul 20, 2026 3:53 PM UTC
​@navid.fotovaty Glad to hear that!
