Removing workspaces from a repository after 30 days?
  • Sep 20, 2023 3:20 PM UTC
  • 64 views
kateaew
Forum|alt.badge.img+11
We have an 'Archived' repository on FME Flow. I was wondering if there was a way to create a workbench or an automation to, for example, delete a workspace after it has been sat in Archived for 30 days.
Thanks
  • Sep 20, 2023 3:41 PM UTC
You can list the contents of the Archived repository using the REST API endpoint:
GET  /repositories/Archived/items
And then this endpoint to retrieve detailed information about each workspace:
GET /repositories/Archived/items/<item>
Perhaps look at the attribute "workspace.lastPublishDate" or something to that effect.
Then delete a workspace using:
DELETE /repositories/Archived/items/<item>
 You can use an HTTPCaller with a web connection to your FME Flow instance for authentication.
Complete API documentation here: https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html
kateaew
  • Sep 20, 2023 3:48 PM UTC
Thank you!
