Recover Deleted Automation
  • Apr 15, 2025 10:23 PM UTC
  • 5 replies
  • 231 views
mccunee
Forum|alt.badge.img+3
I accidentally deleted the wrong automation in FME Flow and I am not able to see how I can recover it.
hkingsbury
Forum|alt.badge.img+73
  • Apr 15, 2025 11:52 PM UTC
When was the last backup run? There may be a copy of it in there. Restoring it will restore everything that is no longer on the server, that may not be appropriate depending on how old the backup is.
Another option is to install FME Flow locally (don’t need a license to install it) then restore the servers backup, then add the automation to a project and export that to the server.
You could also dig into the backup file (its just a zip file with a different extension) and find the automation definition and use that to rebuild it. This is a very advanced approach and probably not worth the effort.
mccunee
  • May 22, 2025 9:39 PM UTC
I think all of these sound rather intense… surprised there is not a “recycling” UI in Flow since accidental deletion is pretty easy and restoring *everything* from the latest backup isn’t necessarily appropriate either.
hkingsbury
  • May 22, 2025 10:34 PM UTC
That would be a good function to have!
It would be worth adding it as an idea here: https://community.safe.com/ideas
deanhowell
Forum|alt.badge.img+24
  • May 23, 2025 7:23 AM UTC
What did you end up doing? I have just done the same
evieatsafe
Forum|alt.badge.img+28
  • Nov 21, 2025 10:51 PM UTC
Hi ​@mccunee I don’t think this is currently supported. An internal issue has been filed to support this in the future (FMEFLOW-26881), we’ll update this thread when this has been implemented with more details. Thanks for your patience!
